wasima
Feb 13, 2020Aspirant
Orbi AX with Gig Internet - Wi-Fi speeds cut in half
Was excited about putting in Orbi Ax so upgraded to Spectrum Gig internet, Wi-Fi speeds are less than half what is coming in via modem. Orbi app reports gig speed download (940) and the correct uploa...
- Feb 14, 2020
Iphone 11 only supports 80hz wide channels. So its best case connection is 1200mbps. Reason why is a 2x2 antenna arrangement is going to hit max link speed of 2400mbps if its running in 160hz. a 2x2 in 80hz max links speed is going to be 1200mbps. That's link speed, throughput is average of 55% of link speed. Some devices do a bit better than this. so hitting 650mbps is within what you'd expect. Again, some devices can hit faster speed either through using 160hz, lower overhead, or 3x3 antenna arrangements.
Feb 14, 2020Guru - Experienced User
so you're wired speeds hit gigabit?
but not your wireless?
Try reading through wireless speed specs and checking out reviews.
the overal speed of wireless has more overhead so your link speed isn't the same as your throughput speed.
