gglazer
Jun 09, 2021Aspirant
ORBI AX with Surfboard
Looking at getting an Orbi because the current router doesn't reach some parts of the house. However, we currently have an Arris Surfboard SVG248AC which is both modem AND router. So, if I plug t...
- Jun 09, 2021
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Jun 09, 2021Guru - Experienced User
Couple of options,
- gglazerJun 09, 2021Aspirant
Many thanks for the complete response.
- FURRYe38Jun 09, 2021Guru - Experienced User
:smileywink:
Just for the record, the Surfboard does have a bridge mode:
https://arris.secure.force.com/consumers/articles/General_FAQs/TG862G-NA-Bridge-Mode-Setup
