Talon38
Dec 17, 2022Tutor
ORBI AX11000 SYSTEM AND EXTENSION QUESTIONS
Greetings! I have 5 Orbi RB960Bs in my home working well together. We are building a dock around 130' from the house and have run a Cat 8 cable to the dock to set up Wi-Fi. What device might we co...
- Dec 19, 2022
Unfortunately there isn't a outdoor version of the 9 series.
Only suggestion would be to put in a outdoor electronics case then you could put in a indoor RBS unit inside of this case:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Outdoor-Satellite/td-p/2129551
AP = Access Point. Just a mode where the router portion is disabled leaving the wifi radios running for wifi access with devices.
Dec 17, 2022Guru - Experienced User
Could just add any ol wireless AP, RBS or a wifi router set to AP mode and connect it to that lan cable running from the home to this area...
- Talon38Dec 17, 2022Tutor
Thanks! I've purchased a WAX630-EP. Maybe overkill?
Mike
- CrimpOnDec 17, 2022Guru - Experienced User
Talon38 wrote:
Maybe overkill?
Probably. Mixing residential and commercial products may be more complicated than you want.
In addition to the Ethernet connection, it might be useful to consider:
- How the unit will be powered?
- How the unit will be mounted?
- Does it need to be weather resistant?
- FURRYe38Dec 17, 2022Guru - Experienced User
At that distance should not be a problem. You can always turn down the transmit power on the WAX if needed. Which depending on the size of the building your trying to cover, you could.
Just know that it won't integrate to the Orbi system like the RBS do. Will be it's down separate WIFI SSID name. You can use same password if you want. Just use the WAX in AP mode. You'll be fine.
Mike
- Talon38Dec 18, 2022Tutor
Thanks for your help! One more question, does Netgear or anyone make an RBS version that would fit my needs? I can't find one. mike
