Netphase
Nov 12, 2021Follower
Orbi AX1800 WiFi 6 Dual-band Mesh Router(RBR350)
I have been through all the step by step setup configuration for my Orbi , with my internet provider and I don’t seem to have internet . The only way I get internet from Orbi is when I connect it to ...
Nov 20, 2021Guru - Experienced User
Any progress on this?
The only way I get internet from Orbi is when I connect it to my original router that was provided by my internet provider ,through an Ethernet cable .Any advise on specific setup that I need to change or install for my Orbi to connect directly to my nbn box?
Thanks
