JackMurray
Jan 12, 2023Tutor
Orbi AX1800 WiFi 6 Dual-band Mesh Router(RBR350)
Hi, I have an Orbi AX1800 WiFi 6 Dual-band Mesh Router(RBR350). Can I buy additional routers to add to my system?
Jan 12, 2023Guru - Experienced User
Satellites, yes.
routers: no.
the routers don't integrate (can still be used in AP mode) but the satellites do
JackMurray
Jan 12, 2023Tutor
Thanks for this. I'm not technical. Do I need to buy extra equipment?
- plemansJan 12, 2023Guru - Experienced User
Isn't that what you were looking for? Adding more coverage? But you were planning on doing it with adding routers.
You want to add satellites. They'd be RBS350 models.
Or what are you trying to do?
- JackMurrayJan 12, 2023Tutor
Yes - I'm using it to boost a signal coming into the house
