COL-2133's avatar
COL-2133
Follower
Nov 29, 2021
Orbi AX4200 - can it connect to Nokia Fastmile?
I recently took up 5G home internet using a Nokia Fastmile 5G modem and I'm wondering if my Netgear mesh satellites operate as satellites to the Nokia..?
The reason I'm asking this is the Nokia website says that its 'beacons' (Nokia call them beacons instead of satellites) are AX4200.  Here are the words from the Nokia  website: Beacon 6 Next-level speed - premium performance. The best Wi-Fi 6 mesh router (AX4200).
The Orbi model is AX4200...is there something common between the Nokia and the Netgear that allows them to work together?
1 Reply
  • Two different brands. They use same nonmenclature as Orbi however, not compatible.
