sullivanpt
Oct 19, 2020Tutor
ORBI AX4200 - Cannot logout
Help I cannot logout of my Orbi Web Admin. When I navigate to http://192.168.1.1 I am NOT presented with a login page; I'm already logged in. If I then press the "logout" button on the top ri...
- Oct 19, 2020
Has a factory reset and setup from scratch been performed since last FW update? If not, try this. Be sure to clear all browser caches. I would use Edge to walk thru the setup wizard. Be sure to write down all important information during the setup wizard process.
Oct 19, 2020Guru - Experienced User
Be sure to clear out all browser caches before entering the web page. Exit the browser then try again.
This happen with other browsers?
Do you save the login info, admin and PW in the browser profie?
sullivanpt
Oct 19, 2020Tutor
Thanks, all good things to check; but it's not a browser auto sign in. I've tried on 2 browsers on my PC: chrome & edge. I've tried from the browser on my phone. I've tried from the browser on my son's PC. None encounter a password prompt.
