EmeP's avatar
EmeP
Orbi AX4200 - RBR750, 3 satellites - computers keep disconnecting during video-calls
Hello,
as mentioned in the title, the wireless connection from my Orbi System (Orbi AX4200, RBR750 - 3 satellites) keeps breaking up during video calls (happens more often when its a call of multiple people) - no matter if Zoom, MS Teams or Google Hangouts.
Happens on a MacBook Pro 2022 with Wifi6, MacOS 12.2.1 as well as on a Lenovo ThinkPad X1, Win10.
Anything I could do about it? With all other devices the connection seems to be stable.
Best,
Emanuel
  • plemans's avatar
    What speeds do you pay for for both upstream and downstream.
    A lot of people find their downstream speeds are fine but have low upstream.
    also, many video conference apps (zoom, etc) have a built in speed/quality test. Try running that.
    What modem/gateway are you connected to?
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try setting CTS values to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
    EmeP wrote:
    Hello,
    Best,
    Emanuel
