ststephengray
Dec 27, 2020Aspirant
orbi ax4200 753S
I’ve got an Orbi AX4200 RBK 753S Tri-band Mesh WiFi 6 system; RBR750 and two RBS 750. House is 3200 sf total, 2-story. We have Cox Giga-blast service. On my Orbi app it shows download speeds of 750...
Dec 29, 2020Guru - Experienced User
Any progress on this?
ststephengray wrote:I’ve got an Orbi AX4200 RBK 753S Tri-band Mesh WiFi 6 system; RBR750 and two RBS 750. House is 3200 sf total, 2-story. We have Cox Giga-blast service. On my Orbi app it shows download speeds of 750 to 940 Mbps (it will vary with tests rarely as low as 750 Mbps but is typically showing above 900). Per the Community pages this is the download speed from the modem to the router. Modem is Arris Surfboard S33 Docsis 3.1.
The highest Wifi speeds we get on any device in our house are very rarely in the 400 Mbps range; but typically they are in the 240-330 Mbps download range. This ranges from older HP laptops (but still Windows 10) and Galaxy S10 to new iPhones and Mac. If I hardwire laptop and desktops the speed only improves about 10 Mbps: right now I’m at 290 Mbps hardwired on an HP E7470.
Why such a drop through the RBR 750? Everyone I talk to says I should be getting 700 to 850 Mbps downloads hardwired, and 600 to 650 Wifi. I have never seen that on any of our devices.
Jan 02, 2021Guru - Experienced User
Hi FURRYe38,
I've responded to your question 4 times now and when I then go back to look my responses do not show up. I sent you a private message on the 29th but have not seen that either that I did send it. I'm not sure what I'm doing wrong but hope this message gets to you. My response to your question was:
Firmware Version is V3.2.16.22_1.4.9
Wired connected speed to back of modem is 940.11 download; 36.69 upload; 7 ping.
Wired connected speed to router is 939.30; 36.85; 6.
Wifi speed to router is 341.17; 36.40; 7. Device is 15 feet away from router.
Wired connected speed to one of satellites is 170.84 ; 36.78; 8 . Satellite is 75 feet away from router; upstairs, in office.
Wifi speed to one of satellites is 229.09; 36.85; 17 . Device is 2 feet away from satellite.
Armor is disabled."
- FURRYe38Jan 02, 2021Guru - Experienced User
"Wired connected speed to one of satellites is 170.84 ; 36.78; 8 . Satellite is 75 feet away from router; upstairs, in office." Can you move the RBS closer to the RBR? Say 55-60feet?
- BDGGrayJan 04, 2021Aspirant
I gave that a try and no noticeable change. Still within the same ranges.
