ststephengray
Dec 27, 2020Aspirant
orbi ax4200 753S
I’ve got an Orbi AX4200 RBK 753S Tri-band Mesh WiFi 6 system; RBR750 and two RBS 750. House is 3200 sf total, 2-story. We have Cox Giga-blast service. On my Orbi app it shows download speeds of 750...
Jan 04, 2021Guru - Experienced User
Is Armor enabled on the RBR?
Try a factory reset on the RBR and walk the setup wizrard. Don't enable Armor. Power cycle the ISP Modem OFF for 30 seconds then back ON. WIth out doing any other changes on the RBR and nothing else connected accept for 1 wired PC, run a speed test using Ooklas installable speed test app.
- BDGGrayJan 06, 2021Aspirant
I did the factory resets, and did a speed test directly hardwired off the RBR750, with Wifi turned off from the device, and the 2 RBSs turned off/disconnected. The speeds on the hardwire increased dramatically: on my wife's Mac we got 886.93 Mbps download, 36.63 upload. So that was quite an improvement. However, when using Wifi, about 25' away from the router (and RBSs connected/powered on), the download fell to 361.72 Mbps, while upload increased what I would consider to be an insignificant amount to 36.79.
- FURRYe38Jan 06, 2021Guru - Experienced User
That would be probably be a good speed result for wifi at that distance. Distance will impact wifi performance. Wireless speeds will never be as good as wired, especially at a distance. Device antenna design will be a factor as well. 2x2 systems will be the slowest. 4x4 or higher should have best results. Most Macs are 2x2. Even my iphone 12 max is 2x2. I presume it's hard to fit much more in to such a small case design. :smileywink:
- BDGGrayJan 07, 2021Aspirant
Great, thanks for the support. Not sure how to mark this as "resolved" but I'm good to go with this.
