ststephengray
Dec 27, 2020Aspirant
orbi ax4200 753S
I’ve got an Orbi AX4200 RBK 753S Tri-band Mesh WiFi 6 system; RBR750 and two RBS 750. House is 3200 sf total, 2-story. We have Cox Giga-blast service. On my Orbi app it shows download speeds of 750...
Jan 06, 2021Guru - Experienced User
That would be probably be a good speed result for wifi at that distance. Distance will impact wifi performance. Wireless speeds will never be as good as wired, especially at a distance. Device antenna design will be a factor as well. 2x2 systems will be the slowest. 4x4 or higher should have best results. Most Macs are 2x2. Even my iphone 12 max is 2x2. I presume it's hard to fit much more in to such a small case design. :smileywink:
