GreggCFO
Apr 30, 2020Aspirant
Orbi AX4200 and 6000 question
I currently have the Orbi AX4200 router and one satellite. You can't buy AX4200 satellites separately and since i need a second satellite, i bought an AX6000 RBS850. I may also need to get another on...
- Apr 30, 2020
No information or experience with 7 series Orbi AX. I can only surmise that they are the same sans the wifi connection rates that differ between the 7 and 8 series. Single strength I would presume should be the same or in the same range.
When connecting RBS via ethernet, then back haul isn't key anymore. Placement is not as critical since the RBS act more like a stand alone AP with the wired backhaul
Apr 30, 2020Guru - Experienced User
