GreggCFO
Apr 23, 2020Aspirant
Orbi AX4200 and connecting it to a router
I have a model from my internet provider and a switch which distributes the internet signal throughout my house but only to certain rooms. Do I need to connect the Orbi router directly to the modem, ...
- Apr 24, 2020
RBS can be more than 30 feet, depending upon building materials. I have one of my RBS out at 40 feet. Others have posted 50 feet as well.
I'd check the wiring the home. Lan connections is preferred for wired connections and best performances over wireless.
Apr 23, 2020Guru - Experienced User
Prefered is connected to the modem.
Howoever depends on what mode you use the Orbi AX in.
If the modem has a built in router already, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Then the RBR can be connected farther down the line behind a switch.
- GreggCFOApr 23, 2020Aspirant
My Spectrum modem is solely a modem with one internet port which supplies the internet. If I connect my netgear 8 port switch directly to that modem, then I can hook my Orbi router directly to the switch and also hook my Orbi satellite directly to the switch for my backhaul?
- FURRYe38Apr 23, 2020Guru - Experienced User
You'll need to connect the Orbi RBR directly to the modem then put the switch after the RBR.
You can connect the RBS via eithernet using the following configuration:
Be aware that soem managed switches and green ethernet featured switch cause problems between the RBR and RBS. IGMP Protocols should be disabled on Managed switches. Green ethernet switches should not be used between them.
- Mikey94025Apr 23, 2020Hero
GreggCFO wrote:My Spectrum modem is solely a modem with one internet port which supplies the internet. If I connect my netgear 8 port switch directly to that modem, then I can hook my Orbi router directly to the switch and also hook my Orbi satellite directly to the switch for my backhaul?
Definitely do not do this. The Orbi becomes your switch and everything, including the satellite, connects to it.
Why should that concern me?
