mirage_man
Sep 01, 2020Guide
Orbi ax4200 and LG OLED amazon and Netflix streaming issues. Buffering and dropping out of 4K
Just purchased an Orbi AX4200 Mesh system along with upgrading my internet service to 400mbps. I sat down to watch a show on Amazon Prime and I'm getting buffering and the video quality constantly dr...
Sep 02, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What devices do you have connecrted to the system?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
- mirage_manSep 29, 2020GuideWell not sure what happened but the issue seems to have resolved itself.
- FURRYe38Sep 29, 2020Guru - Experienced User
Probably not Orbi related. Please mark your thread as solved.
Enjoy.
