jsanni
Jul 15, 2021Aspirant
Orbi AX4200 Doesn't Reconnect Most Devices After Reboot
Hello, I own a Netgear Orbi AX4200/CBR750 which is a modem/router combo and it is running on the latest firmware. I typically have about 30-40 devices connected to the router, and it was working fin...
Jul 16, 2021Guru - Experienced User
\30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Power OFF the RBS. Remove the RBS from the RBRs connected clients page. Power ON the RBS. Press the sync button on the RBS then on the RBR and re-sync the RBS to the RBR.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Set CTS to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings on the RBR.
jsanni
Jul 16, 2021Aspirant
Hello, I have firmware version
V3.2.18.2_1.4.14 |
I have tried the suggestions to no avail. I have my laptop now connected to the router via ethernet, and after restarting the router, my laptop is the only device connected. I have a next door neighbor using wifi.
- FURRYe38Jul 16, 2021Guru - Experienced User
A factory reset and set up from scratch will be your next step.
- jsanniJul 16, 2021Aspirant
Thanks Furry, this actually worked! But what settings can I mess with in the future so that I don't have to factory reset the router each time it power cycles?
Shouldn't have to mess with anything really.
I would make back up configuration to file for safe keeping. In case of a reset, you can just load the backup config fron file.
Hopefully this should keep working for you with out a need for reset.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
https://community.netgear.com/t5/Orbi-AX/RBK753S-update-Rock-solid-in-terms-of-speed-and-stability-since/td-p/2095781/jump-to/first-unread-message
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
