anezthetik
Sep 23, 2020Aspirant
orbi ax4200 experience in a 9000 sq ft home
I had a 9000 sq ft home and my existing router and extenders were not working well. I was going to goi with the new orbi pro 6 that came out this month but those are delayed now? So I went with tw...
anezthetik
Sep 24, 2020Aspirant
There is one ssid that works seamlessly so not quite multiple networks. I guess multiple networks according to orbi, but not for the devices roaming about the house.
I am using firmware 3.2.16.6
Satellites are 50 to 100 foot away from each other.
If things keep on staying the way they are, i may disable firmware updates and try my best to keep it working. The only issue is the nest low battery one, and even that is dying down for some reason (maybe they “learned” to draw more power, lol).
By utilizing the second router, I do feel like i am getting away with something im not supposed to.
Sep 24, 2020Guru - Experienced User
Sounds like the system is working well.
FYI, NG is aware of the NEST issue and we are working with NG on this. Hopefully they can get that figured out.
