mc20002001
Jun 01, 2020Aspirant
Orbi AX4200 on a Fiber vs Cable connection
As a new user to the community, I thought I would offer a comment and small question related to Orbi AX4200 on a Fiber vs Cable connection. I know most people are fortunate to even have one option f...
- Jun 02, 2020
Run it for a while and see how it goes for you.
Jun 01, 2020Guru - Experienced User
What was the Mfr and model of the cable modem you had been using when on Cable?
One issue will be the ATT modem/router. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
The BGWs wifi radios are disabled correct?
Those Arris BGW210 modems are known to have problems with external routers like Orbi.
