mc20002001
Jun 01, 2020Aspirant
Orbi AX4200 on a Fiber vs Cable connection
As a new user to the community, I thought I would offer a comment and small question related to Orbi AX4200 on a Fiber vs Cable connection. I know most people are fortunate to even have one option f...
- Jun 02, 2020
Run it for a while and see how it goes for you.
mc20002001
The cable modem was an XFi Advanced Gateway that comes from Xfinity. Yes, the Fiber modem WiFi is turned off. I wouldn't say I have an issue with the modem fortunately since the Orbi is getting full strength at the source with no problem and I should mention WiFi speeds are equally strong right next to the router. Its just that I get slightly less download from the Arris/Fiber as I get farther away from either the main router or Satellite. At long range the gap is around 20-25% difference. There actually may not be anything wrong at all if its true that the Orbi logic is just handling things differently in an attempt to optimize both up and down speeds.
Jun 02, 2020Guru - Experienced User
