paulhimle
Apr 25, 2020Tutor
Orbi AX4200 (RBK752) and Circle Support
The following is a dramatization of my recent NETGEAR Orbi AX4200 (RBK752) purchase… (Spoiler: Not a good one) Boss (Wife): The kids have total and complete free access to the internet and even...
Apr 26, 2020Guru - Experienced User
Does the default standard access controls work any?
If you want or need Circle, I recommend you find a RBK50 series Orbi system that does support Circle and Armor.
We don't know IF or when Orbi AX will be getting Circle support.
paulhimle
Apr 27, 2020Tutor
I know there are other NETGEAR options out there but I was not interested in them. I don't feel this is a case where I (the customer having been made a commitment) should be required to accept a solution were NETGEAR dosn't at least make an effort to fix the problem. If they have another option/product that does not require me to down grade I am more than happy to listen.
If by standard access controls you mean turning off the individual devices access manually, then yes. If not, I don't think so.
- FURRYe38Apr 27, 2020Guru - Experienced User
Well, you have it then.
You'll need to manually block access until such time as NG makes Circle supported on Orbi AX. Something you can discuss with them.
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Again, no idea if or when Circle is forth coming to Orbi AX.
Good Luck.
