paulhimle
Apr 25, 2020Tutor
Orbi AX4200 (RBK752) and Circle Support
The following is a dramatization of my recent NETGEAR Orbi AX4200 (RBK752) purchase… (Spoiler: Not a good one) Boss (Wife): The kids have total and complete free access to the internet and even...
Apr 26, 2020Guru - Experienced User
Does the default standard access controls work any?
If you want or need Circle, I recommend you find a RBK50 series Orbi system that does support Circle and Armor.
We don't know IF or when Orbi AX will be getting Circle support.
57ay
Jul 29, 2020Luminary
Change the DNS servers to a Child safe one! just as good as using circle.
eg I use
185.228.168.10
185.228.169.11
See cleanbrowsing DNS filters https://cleanbrowsing.org/filters
Enjoy problem resolved.
- FURRYe38Jul 29, 2020Guru - Experienced User
Thank you for letting us know a work around solution. Glad it works for you. Hopefully it will help others that are wanting Circle support.
:smileywink:
Users can also use DDNS servers as well and make configurations on there site. Services like OpenDNS is one.
57ay wrote:Change the DNS servers to a Child safe one! just as good as using circle.
eg I use
185.228.168.10
185.228.169.11
