asachmo
May 03, 2021Aspirant
Orbi AX4200 (RBK752) not full loading websites/mobile apps
Hey All, In the past week or so, I have noticed that I have been struggling to connect to websites (amazon shopping and Orbi app in particular) via my WiFi signal. What happens is that it just par...
May 03, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Tab/Advanced Settings/Wireless Settings
Armor, Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
- asachmoMay 03, 2021Aspirant
Current Firmware = V3.2.18.1 on Both RBR750 and Satellite
ISP Modem = Hitron CGNM-2250 DOCSIS 3.0 modem - Bridged and connected via ethernet cable to Orbi Router
Home Size = 1600sqft
Distance Between Satellite and Router = 20ft
WiFi Neighbours = Two (live in an attached townhouse)
I do not see the option to enable 40MHz coexistence ONLY, just had a check to enable 20/40MHz
Do set CTS to 2347 on both 2.4 and 5GHz settings?- FURRYe38May 03, 2021Guru - Experienced User
asachmo wrote:Current Firmware = V3.2.18.1 on Both RBR750 and Satellite
Distance Between Satellite and Router = 20ft <Too close, try 30 feet.
I do not see the option to enable 40MHz coexistence ONLY, just had a check to enable 20/40MHz <Uncheck the box then apply sets 40Mhz only.
Do set CTS to 2347 on both 2.4 and 5GHz settings? Yes.- asachmoMay 04, 2021Aspirant
Haha ya I am new to this forum, am a little hesitant to try his solution as I seen it in other posts. I really wish there was a solution to the problem. I know its not an issue communicating with the satellite and router - aside from a few websites not loading, literally everything wrongs flawlessly. It almost seems like orbi restricts some websites intermittently for some reason
