JP1234
Aug 16, 2020Aspirant
Orbi AX4200 (RBK753) Compatibility
I am thinking of purchasing the AX4200 and wanted to make sure that I could properly use ethernet backhaul with my home's setup. Our modem is in the basement and connected to a 16 port router. Most r...
Aug 16, 2020Guru - Experienced User
Yes, however some caveats.
What is the mfr and model # of this 16 port (switch)?
CAT5 is old and doesn't provice good performance for 1000Mb networks. You may see problems or bad performance with CAT5. CAT6 is recommended.
- JP1234Aug 16, 2020Aspirant
Thanks for the quick reply! It is a Cisco RV016 Multi-WAN VPN Router. Would CAT6 make a noticable difference? Or is it just a nice to have?
- FURRYe38Aug 17, 2020Guru - Experienced User
Generally better performance over CAT5, CAT5 was only supportive of 100Mbs.
- JP1234Aug 17, 2020Aspirant
Got it, but would a mesh set up still work? I've had some people recommend a multi-AP setup instead, but it's my understanding that a multi-AP setup wouldn't transfer devices automatically to the strongest signal. So you could still be connected to an AP far away with a poor signal when you're in a different room with a stronger one.
