JP1234
Aug 16, 2020Aspirant
Orbi AX4200 (RBK753) Compatibility
I am thinking of purchasing the AX4200 and wanted to make sure that I could properly use ethernet backhaul with my home's setup. Our modem is in the basement and connected to a 16 port router. Most r...
Aug 17, 2020Guru - Experienced User
Generally better performance over CAT5, CAT5 was only supportive of 100Mbs.
JP1234
Aug 17, 2020Aspirant
Got it, but would a mesh set up still work? I've had some people recommend a multi-AP setup instead, but it's my understanding that a multi-AP setup wouldn't transfer devices automatically to the strongest signal. So you could still be connected to an AP far away with a poor signal when you're in a different room with a stronger one.
- FURRYe38Aug 17, 2020Guru - Experienced User
Yes the MESH would still be working.
Well there are other factors in how devices get connected or move from one signal to another. This is called ROAM. Some devices support it some do no. Also it's up to wifi devices to move or roam from one signal to another, Orbi doesn't force devices to move.
