Retired_Member
Aug 30, 2020Orbi AX4200 RBK753 Missing Settings
Hi. Recently purchased and set up the new WIFI6 AX4200 RBK753, and noticed that there are numerous settings that are missing that used to be available for our older Orbi system. Notably, implicit ...
Aug 30, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
NG may have implemented these on a automatic basiis and no longer needs a UI feature. Those feartures would not hinder RBS wireless connections.
