Buflo
Jun 10, 2024Follower
Orbi AX4200 RBK753 Router with 2 satelites
Can I use my old Netgear AX4200 Model DL6400 as the modem? Must it be modified to only act as a modem? If not, can you suggest one? Thanks in advance.
Jun 11, 2024Guru - Experienced User
Model DL6400 is not a valid NG model. Is this a particular brand model? What is the brand?
NG recommends that for any ISP gateway device, something that has a modem or ONT and has built in router and wifi, if you want to add a Orbi system, it's recommended to bridge or put the ISP unit into modem only mode. Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
