Rafa10
May 13, 2021Aspirant
Orbi AX4200 (RBK753) Wifi calling not working and voice calling freezing
Setup is completed, WIFI Calling isnt working (call failed) and any voice calls (facetime, whatsapp, teams, skype) freeze every few seconds. Tried to disable SIP LAG, didnt work firmware is l...
May 13, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Try setting Set 20/40Mhz Coexistence to 40Mhz only and CTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Rafa10
Hi,
I've tried to configure the advanced tab as you described (image attached), still the same :(
Size of the house is 400sq of 3 floors, each router on different floor, all connected with RJ45
Internet router is the ISP's default router (HOTBOX 4, which belongs to a company called Hot in Israel)
Thanks
- FURRYe38May 13, 2021Guru - Experienced User
If the ISP modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
