another_user
Nov 07, 2023Aspirant
Orbi AX4200 RBR750 Guest Network Devices Access to LAN?
Hey everyone, If I turn on my guest network for my Orbi AX4200 RBR750 mesh system, will guest users be able to access my LAN devices that are connected to the router? I have my IoT devices connec...
- Nov 07, 2023
On the Orbi 750 system, devices connected to the Guest WiFi network are isolated from the primary network (including the primary WiFi and the wired network).
Something easy to verify. Connect to the Guest WiFi and attempt to connect to any device on the primary network.
CrimpOn
Nov 07, 2023Guru - Experienced User
- another_userNov 07, 2023Aspirant
Thanks for the fast reply, CrimpOn. I tried that and you are correct that it didn't connect. Thanks for your help!
