tbk361
Nov 18, 2022Aspirant
Orbi AX4200 RBS750 satellite will only get 100Mbps on wired backhaul
Recently I rearranged my home network to wire in some devices and to add an ethernet backhaul. However, I am unable to get speeds above 100 Mbps from the satellite with ethernet backhaul. Details...
Nov 18, 2022Guru - Experienced User
Sounds like a possible faulty RBS that may need replacing if wired connections directly to the RBR are working and the wireless backhaul is working.
When you factory reset the RBR and RBS, did you let the setup wizard add the RBS during the setup process or did you add it later on using the sync buttons?
