tbk361
Nov 18, 2022Aspirant
Orbi AX4200 RBS750 satellite will only get 100Mbps on wired backhaul
Recently I rearranged my home network to wire in some devices and to add an ethernet backhaul. However, I am unable to get speeds above 100 Mbps from the satellite with ethernet backhaul. Details...
tbk361
I tried both methods. Each time, the statistics window said the connection was 1000 Mbps, but the actual connection (wired or wifi) was < 100 Mbps.
Nov 18, 2022Guru - Experienced User
I would contact NG support and ask for a RMA RBS that they could send you and see if a new one resolves this.
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/
