tbk361
Nov 18, 2022Aspirant
Orbi AX4200 RBS750 satellite will only get 100Mbps on wired backhaul
Recently I rearranged my home network to wire in some devices and to add an ethernet backhaul. However, I am unable to get speeds above 100 Mbps from the satellite with ethernet backhaul. Details...
GEBucky
May 20, 2023Aspirant
I had same problem with one of my RBS960. Throttled to just below 100M wired backhaul, and normal full speed without the cable. I was a Cat 5e so should have been fine, but ran a test with a long Cat 6 and it's now operating normally. My lesson learned is always start with the cables. Replacing everything in house with Cat 6 now. It can forever to diagnose these types of issues - cables are super easy to test.
CrimpOn
May 20, 2023Guru - Experienced User
Patch cables are super easy to swap out. Cables embedded in the building structure can be swapped out using a long Cat6 patch cable (100' for $20 on Amazon). Actually testing Ethernet cables requires very expensive test equipment.
