bgrg2000
Apr 20, 2020Aspirant
Orbi AX4200 RBS750 Satellite
I recently puchased the Orbi AX4200 in an effort to equalize the WiFi strength in my home. My ISP (Windsream) is terrible and provides poor speeds (18mbps) but I was hoping to cover the house with a...
Apr 20, 2020Guru - Experienced User
bgrg2000 wrote:Try moving the RBS closer? 50" maybe a bit too far...Try 40 feet.
1) I moved the Satellite to 30' away from the router
2) Firmware says it is up todate but its number is:V3.2.10.10_1.2.12
3) ISP Modem: Windstream Wi-Fi Modem - T3200
What mode is this modem working in? Router or Bridge? If router mode, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
4) NO actual neighbors. The Windstream WiFi is on and a foot from the NG. Also the Ring WiFi is on and about a foot on the otherside of the NG from the Windstream modem. The Ring is running off the Windstream modem via WiFi. Should it be running off the NG? There is also a Nexia Home Hub runing a few Z-wave devices that is directly connected to the NG via Ethernet cable.
Wifi on the modem needs to be disabled fully. Having the modem close to the RBR with both wifi going will be problematic.
Possible noise and interference near the source RBR is causing the RBS to not work well.
Be sure to check your CTS and RTS values. If they are at 64, please change both to 2346. Reboot both RBR and wireless devices. Under Advanced Tab/Advanced Settings/Wireless Settings
5) No clue how to do this, I can't find an advanced tab on the Orbi App
Use a PC or laptop and a web browser to make changes to the RBR.
bgrg2000
Apr 23, 2020Aspirant
Thank you. I have disabled the WiFi in the ISP modem and the signal consistency seems better. The one thing that is bugging me is this CTS and RTS numbers you mentioned. I still can't find my way into the Orbi. I have tried all the courses on my lap top but still can't gain access.
I was also told by Netgear that I can purchase an RBS850 AX6000 Satellite that is compatible with mine and extend the range more.
- FURRYe38Apr 23, 2020Guru - Experienced User
You should be able to access the RBRs web page at orbilogin.com or 192.168.1.1 or maybe a 10.something address...what IP address do you see on your laptop when connected to the RBR?
- JimanatorMay 10, 2020Guide
No problems with laptop software seeing the devices. It's just with the Orbi App.
- FURRYe38May 10, 2020Guru - Experienced User
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
Jimanator wrote:No problems with laptop software seeing the devices. It's just with the Orbi App.
