BigSOB
Oct 30, 2020Aspirant
Orbi AX4200 Router and AX4200 Satellite - Can you disable Microphone
Is it possible to disable the microphones on the Orbi AX4200 Router and AX4200 Satellite devices? Thanks!
Oct 30, 2020Guru - Experienced User
Microphone? I :smileywink: don't believe there is anything of the kind on network routers...
- BigSOBOct 30, 2020Aspirant
Maybe I am missunderstnding this feature on the website:
- Works with Amazon Alexa and the Google Assistant so you can use voice commands to control your home WiFi network.
So, the unit itself doesnt have a microphone and doesnt have Alexa or Google Assistant capabilities? I thought I read someone was having issues with those features.
Thanks,
Justin
FURRYe38 wrote:Microphone? I :smileywink: don't believe there is anything of the kind on network routers...
- FURRYe38Oct 31, 2020Guru - Experienced User
Ya the Orbi doesn't have a microphone. I may work with Alexa enabled devices like Echo Dots or if you install a RBS40v which V is for Voice. Otherwise the Orbi AX itself is just a wifi system only. No Voice.
