grunr
Oct 08, 2023Aspirant
Orbi ax4200 Satellite wont sync
I just purchased the Orbi ax4200 tri band mesh wifi 6 (3 pack - one router and 2 sat's). The first satellite is synced up with router just fine. The second satellite is impossible !! I have tried...
- Oct 13, 2023
yes. thanks for follow up. I replaced the sat unit with a new one and it connected to the network in less than 2 minutes. al good now
Oct 08, 2023Guru - Experienced User
Turn OFF the working RBS.
Bring the one non working RBS to same room as RBR.
Ethernet connect the RBS to the back of the RBR.
Does it get a proper IP address after 3-5 minutes? If so, use this IP address to log into the RBS web page and check it's FW version. All RBS need to be updated to same version of FW as what the RBR is using.
What FW version is on the RBR and working RBS?
- grunrOct 09, 2023Aspirant
thank you,. I will try this today and return here to give report/feedback.
- FURRYe38Oct 09, 2023Guru - Experienced User
i am typing the ip address in as follows http://192.168.1.25 and it wont connect
the sat unit in question is still connected to back of router. Should i put it direct plug in to desktop ?
