grunr
Oct 08, 2023Aspirant
Orbi ax4200 Satellite wont sync
I just purchased the Orbi ax4200 tri band mesh wifi 6 (3 pack - one router and 2 sat's). The first satellite is synced up with router just fine. The second satellite is impossible !! I have tried...
- Oct 13, 2023
yes. thanks for follow up. I replaced the sat unit with a new one and it connected to the network in less than 2 minutes. al good now
grunr
Oct 09, 2023Aspirant
thank you,. I will try this today and return here to give report/feedback.
Oct 09, 2023Guru - Experienced User
- grunrOct 09, 2023Aspirant
i am typing the ip address in as follows http://192.168.1.25 and it wont connect
the sat unit in question is still connected to back of router. Should i put it direct plug in to desktop ?
