JackaMo
Jun 28, 2021Tutor
Orbi AX4200; Slow Download, Fast Upload
Hi, I have a gigabit fiber connection through CenturyLink, and my wired connection hits those speeds. However, my 5ghz wifi download speeds seem to be capped between 180-250Mbps, but upload speeds a...
- Jul 30, 2021
Hello,
Thanks for the response. I believe that I discovered the culprit: my Sony ST-HT5000 soundbar. The subwoofer connects to the sound bar wirelessly and it was connecting at the 5.8 GHz RF Band. After I switched that to 5.2 GHz, and tested devices connected to the satellite, I am getting between 600-700 mbps.
Unfortunately, because the router and soundbar are in the same room (about 10 feet apart), there is still some interference; speed results are between 300-400 mbps for devices connected to the router.
Not a perfect solution but is doable.
JackaMo
Jul 01, 2021Tutor
Yes. Just to clarify, aren't those 3 options only for two routers (so in my situation running the Orbi through the Zyxel C300z)? When using just the Zyxel modem/router or using just the Orbi, the issue with wireless download speeds exist. If using only the Zyxel and not the Orbi, are there any recommended solutions?
Jul 01, 2021Guru - Experienced User
IF you use the Zyxel in front of the orbi as your host router, options #2 and #3 can be used with that unit.
