Splattoramus
Nov 28, 2021Aspirant
ORBI AX4200 strange issue with connections
Hi All, I am hoping you can help. I bought the Orbi AX4200 (RBR750) Mesh System in January 2021 and added an additional satellite in March, and I was truly amazed at the speeds and coverage. I ...
Nov 28, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- SplattoramusNov 28, 2021Aspirant
As for the MFG/Model, not sure that matters...since the upstream is posting the expected numbers. It is only downstream from the Orbi that is suffering. :)
As for the power down, I didn't wait a full minute, but did use the old default of count to 15 slowly to allow network connection cache to clear before turning on the modem and letting it settle before powering up the Orbi. Total about 5mins of downtime in the house for internet...but I can cetainly try to unplug the modem for a full minute, press the power a few times to remove all flea power, and then bring it all back online. :)
