doghound
Oct 21, 2020Star
Orbi AX4200 Transmition speed between Router and Satellite
Is there anyway to see the Tx Rate between the router and the satellite? The only information I can find is the "Stastics Screen", but that shows my WLAN Backhaul speed is only 1200M (which is half of the promised 2400M). The option to telnet is gone and, even still, it sounds like satelitteinfo wifi command is gone.
Does anyone have a way to figure this out? Otherwise I have to assume my devices are not getting the 2400M as per the tech spec sheet.
- Thanks. While related and I, too, am only seeing 1201Mb on my back haul (instead of 2400Mb), my question here is different.
I am looking to see if I can see the actual Tx rate between Orbi devices. Or, as the Orbi app calls it, the Link Rate between satellite and router. Image below is how it looks in the app for my phone.- FURRYe38Guru - Experienced User
Please make contact with NG support and let them know if your experiences.
