ogdl
May 20, 2020Follower
Orbi Ax4200 vs Nighthawk Ax6000
Hi - I can't get a straight answer anywhere - can someone give a low tech person a hand? I got both the Orbi ax4200 and Nighthawk ax6000 (one person recommended one and then when I went to pick it u...
May 20, 2020Guru - Experienced User
Compare the spec sheets over on NG download site for each model. Down towards the bottom you will see differences. Mostly the connection rates are different.
Armor is now support on both 7 and 8 series Orbi systems. Circle is not as of yet.
