redleader-NET
Mar 04, 2021Aspirant
Orbi AX4200 w/ Xfinity (Comcast) gateway
Hello there, So my house currently uses an Xfinity gateway (using both modem and router features). However, tons of slow/dead spots in the house so I plan on getting the Orbi AX4200 mesh system....
Mikey94025
Mar 04, 2021Hero
redleader-NET wrote:Hello there,
So my house currently uses an Xfinity gateway (using both modem and router features). However, tons of slow/dead spots in the house so I plan on getting the Orbi AX4200 mesh system. I understand that I need to set the gateway to bridge mode so that the gateway stops serving as a wifi router, handing over those duties to the Orbi. The only service/equipment that I also have from Comcast is their security camera system. However, the cameras are wired directly to a video device that is then directly wired to the gateway. So since the cameras are not wifi based, is it safe to set the gateway to bridge mode?
You should be able to connect the video device to the Orbi instead of the Comcast gateway. Essentially, your Orbi replaces the gateway so reconnect everything to the Orbi base or satellite. The only thing wired to the gateway will be the Orbi base.
