redleader-NET
Mar 04, 2021Aspirant
Orbi AX4200 w/ Xfinity (Comcast) gateway
Hello there, So my house currently uses an Xfinity gateway (using both modem and router features). However, tons of slow/dead spots in the house so I plan on getting the Orbi AX4200 mesh system....
Mar 04, 2021Guru - Experienced User
Please visit and post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
redleader-NET wrote:Hello there,
So my house currently uses an Xfinity gateway (using both modem and router features). However, tons of slow/dead spots in the house so I plan on getting the Orbi AX4200 mesh system. I understand that I need to set the gateway to bridge mode so that the gateway stops serving as a wifi router, handing over those duties to the Orbi. The only service/equipment that I also have from Comcast is their security camera system. However, the cameras are wired directly to a video device that is then directly wired to the gateway. So since the cameras are not wifi based, is it safe to set the gateway to bridge mode?
