Codeman519
Jan 18, 2023Aspirant
Orbi AX4200 WiFi 6 High-Performance Router (RBR750) internet issues
Hey guys and gals! I had recently purchased a Orbi AX4200 WiFi 6 High-Performance Router (RBR750) and I have been having issues with disconnecting from internet while downloading larger files/upd...
Codeman519
1. I have 2 satellites
2. all 3 is Firmware Version
V4.6.9.11_2.3.5
3. 2500 sq. feet
4. Not sure what you mean? It's on auto I believe.
5. Yes
6. No, just when downloading larger files. I also tried different game clients, and still happens.
7. Direct connection from outside? Bare with me, but the LAN connection cable comes in from outside and I have directly attached it to the router.
I want to be clear however, that this has not happened before. It used to work just fine. I have not downloaded anything to mess around with anything with the router or internet. I am also connected with a wired connection for the PC. But still goes down when downloading. Also, I have 1g of internet speed, and I run speed tests all the time, and get great speeds(900+). Think that's all that I got. Thanks!
tucsontico
Jan 23, 2023Virtuoso
Are you certain your ORBI is a model RBR750 and not a CBR750? You say you have a "direct connection from the outside". If your ORBI does not contain a built-in Modem (CBR750), in order to function correctly, there must be either a cable modem or an ONT (Optical Network Terminal) inline before your ORBI router.
The current and latest firmware version for the RBK750 series is V4.6.14.3_2.3.12.( If you actually have an CBR750 the current firmware is V4.6.14.4.) I suggest you download that firmware and update your system starting with the satellites. If possible, do the firmware update via a laptop connected via a CAT 6 cable.
DO NOT use the Orbi app to update firmware. Sign in to the web-based User Interface (UI) via a web browser with the satellite IP address, e.g., 192.168.1.xxx and select the Advanced tab>Administration>Firmware Update>Manual Update. Work methodically and allow each satellite to reboot, stabilize and reconnect to the router BEFORE attempting to update the router. Once the router has been updated and reestablish contact to the sats and your devices, power down your entire WiFi system (router, satellites, and modem) for at least 1 minute. Then bring them back online one at a time, i.e., Modem, router, sat 1, sat 2. Allow everything several minutes (5-10) to stabilize before doing any speed tests or other performance checks.
Good luck!
