jack0707
Feb 07, 2022Follower
Orbi AX4200 WiFi 6 High-Performance Router (RBR750)
Internet speed doesnt stay consistent after about 3 or 4 days it drops from a gig to about 80mb. Only solution thus far is a reboot? Up to date on firmware.
Feb 07, 2022Guru - Experienced User
How are you speed testing? Wired or Wireless?
What devices are you using to speed test with?
Is Armor, Smart Parental Controls enabled?
