naveenezone
Jun 12, 2024Aspirant
Orbi AX4200 WiFi 6 High-Performance Router (RBR750)
Hello Community, I have purchased the below product and it has 2 satellite already and I would like to know if I could add 2 more satellites Orbi AX4200 WiFi 6 High-Performance Router (RBR750) RBR...
naveenezone
Jun 13, 2024Aspirant
How many satellites does RBR750 supports? Can it support 4 satellites like this combination below.
RBS350 -2 nos
RBS750-2 nos
My firmware is at level v4.6.11.1 at the router RBS 750 and also at the satellites at v4.6.11.1
Jun 13, 2024Guru - Experienced User
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System 📡 🛰️
Be sure if you get two RBS750s, they will need to be on same V4 FW as the currently running system.
- naveenezoneJun 17, 2024Aspirant
1,520 sq feet. I don't have any firewall installed.
- FURRYe38Jun 17, 2024Guru - Experienced User
For that size of home, the RBR and just one RBS750 should work well for you. Having that many RBS maybe over saturating the home and causing problems. Too Much Wifi: https://youtu.be/UR0viMLISz4
30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
