Paul2323B
Apr 24, 2022Aspirant
Orbi AX4200 WiFi 6 Router (RBR750) doesn't detect internet connection
My router isn't detecting the internet connection from my modem. However, I know the internet connection is good because I can use an ethernet cable to connect my PC to the modem and have access to t...
Apr 24, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Paul2323B
Apr 25, 2022Aspirant
Firmware version: 4.6.7.13
ARRIS SB6190 modem (not provided by ISP [Comcast] but it is compatible with Comcast's signal)
Yes, the power off/on cycling has been completed since the last update.
I followed your instructions and the router cannot make an internet connection.
My computer is only functional with an ethernet connection from the modem.
- FURRYe38Apr 25, 2022Guru - Experienced User
What's the connection rate show on the Connection Status for the WAN port on the RBRs web page under Advanced Tab?
What is the CAT# LAN cable between the modem and RBR? CAT6 is recommended.
Also, be aware that the SB6190 has a vulnerability and is not recommended.
- Paul2323BApr 25, 2022Aspirant
Thanks for your follow-up. Earlier this morning, I called Netgear Tech support and they were able to resolve the issue for me.
I wasn't aware that the SB6190 had a vulnerability. Thanks for sharing that information. I'll look at replacing it in the near future.
Let us know what NG support did to resolve this for you...Might be help for others to know.
