Paul2323B
Apr 24, 2022Aspirant
Orbi AX4200 WiFi 6 Router (RBR750) doesn't detect internet connection
My router isn't detecting the internet connection from my modem. However, I know the internet connection is good because I can use an ethernet cable to connect my PC to the modem and have access to t...
Paul2323B
Apr 25, 2022Aspirant
Firmware version: 4.6.7.13
ARRIS SB6190 modem (not provided by ISP [Comcast] but it is compatible with Comcast's signal)
Yes, the power off/on cycling has been completed since the last update.
I followed your instructions and the router cannot make an internet connection.
My computer is only functional with an ethernet connection from the modem.
Apr 25, 2022Guru - Experienced User
What's the connection rate show on the Connection Status for the WAN port on the RBRs web page under Advanced Tab?
What is the CAT# LAN cable between the modem and RBR? CAT6 is recommended.
Also, be aware that the SB6190 has a vulnerability and is not recommended.
- Paul2323BApr 25, 2022Aspirant
Thanks for your follow-up. Earlier this morning, I called Netgear Tech support and they were able to resolve the issue for me.
I wasn't aware that the SB6190 had a vulnerability. Thanks for sharing that information. I'll look at replacing it in the near future.
- FURRYe38Apr 25, 2022Guru - Experienced User
Let us know what NG support did to resolve this for you...Might be help for others to know.
- Paul2323BApr 27, 2022Aspirant
I needed to renew a tech support subscription to resolve the issue I was having with my Orbi router.
Netgear's tech support person performed remote diagnostics and assured me there was no hardware issue. He had me go through a series of steps to do a factory reset of my Orbi router (I had to depress the reset button for a full 60-seconds.) Then we did a web-based log-in for the router set-up because I could not detect an internet connection with the mobile app on my phone. The tech was patient and walked me through all of the various screens required to set up the router correctly. I confirmed that I had a Wi-Fi signal to my desktop and my wife's phone. However, I still did not have a connection on my phone. The tech said that was not unusual and that I should turn my phone off for 30-120 minutes. So I shut down my phone for a total of two hours. After which time, I powered it back up, opened my settings, went to Wi-Fi, opened information, touched "Forget this network," then let my phone find my Orbi network, and reentered my password and my phone connected to the internet.
However, my phone again dropped and could not reconnect to the internet the next day. After a quick check on the internet, I found a link to an article entitled "How to keep your iPhone from repeatedly dropping Wi-Fi network connections." Following the steps in this article, I reset my network connection, and I no longer have an issue with my phone dropping its connection to my Wi-Fi.
Getting my router up and running took about 56-minutes of time on the telephone with NG tech support. And the time and money to get that support were well worth it to me.
The following email text and links were provided by Netgear support.
Thank you for contacting NETGEAR. I am happy that I was able to assist you in resolving your case today. Here are some NETGEAR articles that will provide helpful information and troubleshooting steps.
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
I hope that the KB link(s) I have provided will help you in the future. If you have any additional issues in the future, you may visit the following NETGEAR support portals to get assistance on your NETGEAR product
for free NETGEAR knowledge base
https://www.netgear.com/support
for free NETGEAR online community
for a free NETGEAR video tutorial
https://www.youtube.com/c/netgear
Thanks and Regards,
Netgear
