Glitch01
Aug 28, 2022Aspirant
Orbi AX4200 WiFi 6 Router (RBR750) Random Reboots
Solved my issue with my Orbi AX4000 (RBR750) rebooting randomly or loosing wifi connectivity especially on the guest network and want to share what fixed it for me. Reboots occurred every few days a...
Aug 29, 2022Guru - Experienced User
So you have two wifi systems running at the same time?
What FW version do you have loaded on the Orbi system?
What channels are you using one each system?
Glitch01
Aug 29, 2022Aspirant
Yes, I have 2 AP's running on two separate vlans. I'm running on the latest available firmware, V4.6.8.2_2.1.9 on the Orbi. The other AP is running strictly on 5 GHz band using 80 MHz bandwidth. I've been stable on the router for over 10 days now with 20/40 coexistence disabled, but stability does come at a cost of speed on 20 MHz. Just for kicks I've enabling 20/40 coexist at 25% power on the 2.4 GHz band & 50% power on the 5 GHz band. The Orbi does not have any available options for the bandwidth for 5 GHz.
- ekhalilAug 29, 2022Master
Glitch01 wrote:....... I'm running on the latest available firmware, V4.6.8.2_2.1.9 on the Orbi. .....
The latest firmware is v4.6.9.11, among other things it solves issues with random restarts, you might want to try it. I have this firmware on all my Orbi's. https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR750-RBS750-Firmware-Version-4-6-9-11-Released/m-p/2252422#M37353
- Glitch01Aug 30, 2022Aspirant
Update was released on 8/22/2022. Today is 8/30/2022 and the Orbi does not say there is a new update. Saw the reports on the forum of reduced through puts & I'm wondering if it has to do with them disabling 40 MHz in saturated locations. As stated, 40 MHz creates unavoidable interference.
No harm in trying the new firmware. Saw a bit of downtime on the guest wifi on the Orbi this morning & I'll chock it up as insignificant on 20/40 coexhistence enabled at 25% power. I still recommend disabling this option is you are having reboot/freeze issues or frequent wifi downtime. I'll report back with additional testing on the 4.6.9.11 firmware.
Coexistence disable, 40 MHz will be forced causing possible wifi interference with your neighbors. In light, it is better to reduce the wifi strength on 2.4 GHz and leave the option enabled to see if it will solve your reboot/freeze issues.
