Glitch01
Aug 28, 2022Aspirant
Orbi AX4200 WiFi 6 Router (RBR750) Random Reboots
Solved my issue with my Orbi AX4000 (RBR750) rebooting randomly or loosing wifi connectivity especially on the guest network and want to share what fixed it for me. Reboots occurred every few days a...
ekhalil
Aug 29, 2022Master
That is strange! It should be the other way around, as I understand it! 🙂 The setting "Enable 20/40 MHz Coexistence for 2.4 GHz band" says that if the quality of the connection is bad, then you accept to go down to 20 MHz bandwidth. When this is disabled, it means that you only accept 40 MHz, so either 40 MHz or nothing, which will make the connection vulnerable to band satuaration.
Cinemagic310
Feb 04, 2023Guide
Does it matter if you raised the DNS pool to 100-200?
