qumhh's avatar
qumhh
Orbi AX4200 with AT&T Fiber setup
The issue I'm having is my Orbi never gets past the blinking 2nd light (download) and I can't complete setup. I previous had Xfinity, I tried setting up passthrough and certain devices could connect, some could not. So I factory reset both the AT&T modem/router and then Orbi but now setup basically halts at that point. I tried putting the AT&T Router into passthrough mode with the Mac Address from the Orbi but still no internet is being delivered to the device. I also turned off the Wi-Fi radios for the AT&T router/modem and I'm just stuck at setup. I know this is a cable Orbi but I've seen other people use this with Fiber so I was hoping for some advice. I've read through multiple posts on here on exactly what to do but am still having an issue. Any advice would be appreciated, thank you.
  • CrimpOn's avatar
    CrimpOn
    what is the actual product number printed on the label (bottom of case)?
    (AX4200 is a marketing description made from combining maximum theoretical WiFi speeds, not a product number.)
  • plemans's avatar
    This makes me think its not a router only device but modem router combo device like the CBK752.
    If that's the case, thats not compatible with ATT fibre. It has a modem only mode, a modem/router mode, but not a router only mode that you'd need with att.
