LawKrush
Jul 25, 2020Aspirant
Orbi AX4200
Hi all, I just bought the new Orbi Ax4200 and it worked perfectly for the first couple of hours. Then I noticed when I would connect on the satellite, my speeds would drop drastically. When it ...
Jul 25, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
LawKrush
Fireware
V3.2.15.25_1.3.15 |
Xfinity X1 - 1 Gig/Fiber
Router mode.
The xfinity is also broadcasting wifi too because I have xfinity wireless boxes in the house, so I cant bridge (from what I have been told)
Its prolly 40-50 feet and downstairs. Its across the house from the router.
2.4 is auto
5 is 48
all neighbors are wifi i assume in on my street maybe 15 homes.
I will try changin the channel on the 2.4
- FURRYe38Jul 25, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? IF this modem has a built in router and wifi, this maybe problmatic for you. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
