Rzing07
Aug 20, 2023Follower
Orbi ax5700
Current orbi AX5700 (rbr840) and just built a Pavillion in backyard. Have decent signal and want to strengthen it to ensure Sonos and streaming tv work. Could I get the AX1800 wifi mesh extender Vs another satellite. Will it work with Orbi and what are pros and cons? Thanks!
1 Reply
Will it work? Sure. I've attached extenders to my orbi setups before.
Cons:
- it doesn't integrate with the system
- roaming isn't as efficient as it isn't part of the mesh
- that can impact stability
- since its not integrated, nothings controlling the extender unlike the orbi system has the router managing it
- you'll have to use different apps/web gui's to manage the 2x systems
Pro's: Its cheaper.
